Wiring up 3 wire o2
Old Dec 28, 2011 | 07:47 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Wiring up 3 wire o2
I have a heated oxygen sensor on my car and was wondering where would be a good spot to put the power wire for the heater to. I had it wired in with the fuel pump but the fuse for the fuel pump always blows when I turn the key on. What else would be a good circuit to wire it in with?
Old Dec 28, 2011 | 09:31 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
Re: Wiring up 3 wire o2
I used the line that goes from the relay to the pump (it is energized if the engine is running or when the key is first turned) to trigger another relay that powers the O2 from the battery. It hasn't blown a fuse yet.
Hope this helps.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
stalkier
Aug 21, 2015 01:54 AM
