Which is the zero timing pointer tab?
Old Jan 4, 2012 | 02:37 AM
Cosmik Debris's Avatar
My timing tab is a bit rusty, it is the standard one on an 84 Trans Am. Can someone tell me which tab is the zero and what the numbers are on the others?
Old Jan 4, 2012 | 04:43 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Which is the zero timing pointer tab?
Steel wool and/or Scotch Brite is your friend.
Old Jan 4, 2012 | 06:04 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Old Jan 4, 2012 | 02:25 PM
midge54
Dec 27, 2019 04:14 PM
masonta
Aug 31, 2015 10:14 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
z28addict8490
Aug 7, 2015 08:48 PM
