LT1 Rod Question
Old Jan 3, 2012 | 06:50 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
LT1 Rod Question
Will these rods work on an LT1?
It says they are good for a Gen 1 small block but doesn't mention Gen 2 (LT1). Why would that be? I thought rods and pistons were interchangeable between gen 1 and gen 2 small blocks.
http://www.summitracing.com/parts/CPI-A5700DS2A2AH/
Old Jan 3, 2012 | 07:03 PM
rocko350's Avatar
Car: 1991 caprice / 96 caprice
Engine: 4?? bbc / lt-1
Transmission: 700r4 / 4l60e
Axle/Gears: 4.10/ 3.73
Re: LT1 Rod Question
Should be fine. Remember that the Lt-1 uses a lighter piston and rod combo than standard GEN1 SBC's. You will need to rebalance the assembly before final assembly.
Chris
Old Jan 3, 2012 | 07:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Yes
Because it is a commercial website ; not a online ref library.
Common to have wrong or omitted info.
Do your own research elsewhere
Old Jan 3, 2012 | 07:07 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Originally Posted by vetteoz
Yes
Thank you. I always ask you guys at ThirdGen because I get faster responses and more accurate answers then the 4thgen forum.
I figured it would work but I'd rather be safe.
Old Jan 3, 2012 | 07:08 PM
Well, considering that LT1 rods work fine in older versions of the 350 (and any other 5.7" rod SBC), I see no reason why the reverse wouldn't also be true.
Old Jan 3, 2012 | 08:01 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Your good to go
Old Jan 4, 2012 | 12:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
He meant other than on the Summit website (I hope that's what he meant, anyway).
Old Jan 4, 2012 | 01:48 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Summit is one of the best sites but understandably ;given the large inventory of parts they carry not unusual to find discrepancies or in above case above incomplete listings
Old Jan 4, 2012 | 02:44 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I researched it. I knew the Gen 1 & 2 rods were interchangeable but I wanted to double check since summit didn't make mention of it.
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Dec 4, 2016 11:47 AM
midge54
Aug 29, 2015 09:51 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
