Replaced starter now no power at all. Help??
Old Jan 6, 2012 | 03:14 PM
jpearcy1's Avatar
Car: '87 Iroc
Engine: 350 TPI with Holley Terminator X
Transmission: 4L60e
Axle/Gears: Stock/ Factory
Yesterday I replaced the starter on my dads 1986 trans am and when I went to start car but no power to anything. I un hooked the battery before I took old starter out and have reconnected the wires to the correct places. I have even replaced the positive wire on the battery terminal. I have spent all day double checking my connections. I have checked my ground and have a good ground. Any help would be great! Thanks
Edit: Just replaced Ground cable few mins ago no effect.
Old Jan 6, 2012 | 04:29 PM
Sheppard's Avatar
Car: 84 Trans Am
Engine: 305 for now
Transmission: 5spd
Re: Replaced starter now no power at all. Help??
make sure the connections on the starter are good, tight and clean, did you clean and lightly sand the block of your engine where the starter bolts on, thats where there starter grounds to, very important for that to be clean, if everything checks out, check you battery wires for resistance, can be a break in the wire somewhere or a fuseable link.
Old Jan 6, 2012 | 04:41 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Checked starter with meter and i have power at the starter and my alternator. I haven't found a fuse able link. I also have new battery cables, power on ground that i bought and put on today. I am about to drop the starter and have it checked.
Old Jan 6, 2012 | 06:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Read post #16 here:
https://www.thirdgen.org/forums/tech...aro-again.html
Old Jan 6, 2012 | 07:08 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
id say you missed rehooking a wire.
Old Jan 6, 2012 | 07:16 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Originally Posted by 305sbc
Nice thread and I'll check again on my wires but I am positive I have it correct. I'm about to climb under it again and double check everything again.
Old Jan 6, 2012 | 07:28 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The point of my post is that it very often happens that the copper strands inside the wires will break during a starter R&R.
The wires can be hooked up right and look fine on the outside, but be broken on the inside. You have to test each one.
Old Jan 6, 2012 | 07:53 PM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
Ok thanks for the tip I'll check them.
Old Jan 7, 2012 | 10:52 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Turn the key to the on position, turn on the flip up head lights switch , and go under the car and jiggle the positive battery cable at the starter. That happened to me once. Had no power at all in the car.
Old Jan 7, 2012 | 11:00 AM
jpearcy1's Avatar
Car: '87 Iroc
Transmission: 4L60e
I have no power to do that. My dome light won't even come on when I open the door.
Old Dec 12, 2015 | 01:01 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
Sorry to bump such an old thread but I'm having this exact same problem. Did you ever figure out what was wrong and get it fixed?
Old Dec 13, 2015 | 11:49 AM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Hope this helps.
Old Dec 13, 2015 | 11:51 AM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
90% of all electrical issues are usually with in 2 ft of a connection..
Old Jan 2, 2016 | 11:21 PM
Car: 91 GTA
Axle/Gears: stock
So I finally got around to looking into this issue after all the rain and the holiday travels. Turns out I had a bad battery and also forgot to reconnect the battery terminal on the starter . All is good now.
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
