Fuel line hose size
Old Jan 6, 2012 | 04:25 PM
jlex300's Avatar
Car: 1987 IrocZ28 350
Fuel line hose size
Ok guys have a question. Been looking on the site figured someone would have done this and I'd be able to ask them, but couldn't find anything.
I'm looking to replace the 2 rubber fuel lines that are right in front of the master cylinder. They come off the hard line on the body of car and then run up in a upside down U shape and then attach back into a hard line that then goes into tpi. I want to replace ONLY the rubber part, not all the way to the tpi.
Looking to put 2 steel braided hoses where the rubber ones are. Need to know what exact fittings I will need to make this conversion. I want to get the red/blue anodized hose ends that jegs or summit sell. The way I figure I'm going to need 8 total pieces to do this, plus the hose.
If anyone can help I would appreciate. ASAP. Thanks.
Old Jan 6, 2012 | 05:00 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel line hose size
3/8 and 5/16 you can convert the to an 6 with earls
http://www.summitracing.com/parts/EAR-9894DBHERL/
http://www.summitracing.com/parts/EAR-9894DBJERL/
Old Jan 6, 2012 | 05:28 PM
jlex300's Avatar
Do I get 2 of each of these? And what about the hose ends ?
Old Jan 6, 2012 | 05:47 PM
Engine: Lb9
Transmission: M20
get 4) EAR-300106ERL 2) 9894DBHERL 2)9894DBJERL and on a 87 tpi I think each hose is 12 inches long so 2 feet of an -6 (you might want to measure your lines.
http://www.summitracing.com/parts/SUM-230603/
http://www.summitracing.com/parts/EAR-300106ERL/
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
toronto formula
Nov 10, 2015 06:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
