Question about a/c/smog removal.
Hey guys.
My a/c froze up and so I'm in the process of removing it and my smog. Quick question though. There is three serp. pulleys in the molding that holds the a/c and smog. There's one on the a/c unit, one the on the smog and one little one in the corner. I'm guessing you're not supposed to remove the entire molding and just the smog and a/c, eliminating just two pulleys? I'm planning on buying a shorter belt, but would I need to use the small pulley? I'm not really sure what it does, so maybe someone could clear it up for me.
Thanks.
Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Question about a/c/smog removal.
dorman 34157 is all you need.
https://www.thirdgen.org/serpentine
http://www.ebay.com/itm/1988-1989-Ch...#ht_1321wt_967
Is there anyone not running a pulley? I would like to avoid this at all possible. I would even leave the smog in there if someone could give me the belt size for just the a/c delete. Does anyone have a belt size for these deletes? I've searched the forum everywhere and can't find a sure-fire answer.
