TPI ignition timing
Old Jan 10, 2012 | 11:40 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
TPI ignition timing
so,no i dont haave a underhood sticker.if i did ,well that would be easy.HOWEVER if anyone knows what the FACTORY ignition timing is for a bone stock 86 IROC with a TPI 305 and 700r4.i would surely appriciate it.i cant seem to get a straight answer.thanks!
Old Jan 10, 2012 | 12:17 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: TPI ignition timing
6* BTDC
Old Jan 10, 2012 | 12:28 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by TPI-Formula350-
6* BTDC
What TPI-Formula350 posted. Be sure to open the EST/BYPASS connector and set the timing with the engine warmed up.
RBob.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
