Compression stroke PSI
Old Jan 12, 2012 | 03:41 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Out of couriosity, what is the PSI in a cylinder just before ignition?
Old Jan 12, 2012 | 04:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Compression stroke PSI
Varies with the CR of engine
http://en.wikipedia.org/wiki/Compres...pressure_ratio
Old Jan 12, 2012 | 05:19 PM
Damon's Avatar
Also varies with WHEN the spark happens. If you run a compression test on your engine you'll probably find it reads about 160 PSI or so. But that's the PEAK reading (at TDC) with no spark present. Since the spark fires BEFORE TDC by some number of degrees the cylinder pressure would be less than that- maybe 100 PSI (guessing). When the motor is actually running (combustion is taking place) peak cylinder pressures usually happen around 15* AFTER TDC (if the timing is close to optimum) and they're much higher than cranking compression numbers since the a/f mix has begun to burn and expand.
FormulasOnly
Jul 23, 2018 08:47 AM
dusterbd
Sep 29, 2015 08:40 AM
