spark plug recomendation
Old Jan 11, 2012 | 08:39 PM
franks89's Avatar
plan on tuning up the car, an '89 formula 350. what plugs do you guys recommend useing?
also i see i could use various thermostats 160, 180, 195 degrees. what should i be using in new york?
thanks in advance?
Old Jan 11, 2012 | 09:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: spark plug recomendation
also i see i could use various thermometers 160, 180, 195 degrees. what should i be using in new york?
thanks in advance?
thermometers
Old Jan 11, 2012 | 09:35 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
AC-Delco R45TS gaped at .035 are stock and what I have always used, and its called a"Thermostat" and I'm running a 180*.It is about the best all around temp.(there are other things to take into consideration like fan switch temps,etc. but overall I think a 180* gives the best of both worlds.)
Old Jan 11, 2012 | 09:44 PM
franks89's Avatar
my bad, meant thermostat. thanks ronusmcmma. tunedperformanc, thanks for your comment to i guess
Old Jan 12, 2012 | 05:29 PM
torque_is_good's Avatar
will you have the car for more than 2 years?
if so, then what ever platinum plugs are on sale for $2.99 each will work just swell
If not, then what ever copper plugs are on sale for $1.79-$1.99 each will also work just swell
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
