roller tip rockers?
Old Jan 16, 2012 | 09:45 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
roller tip rockers?
im thinking of using some 1.6 roller tip rockers on my otherwise stock engine.it is a oe roller lifter motor already .so im thinking why not? does anyone know if they will fit with no mods? stock valve covers too?
Old Jan 16, 2012 | 09:56 PM
Re: roller tip rockers?
Yes, except for possibly needing to lengthen the push rod holes toward the studs.
Stock valve covers, of course; as long as the Poly-Locks (if you use them) aren't too tall.
Old Jan 16, 2012 | 10:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Not sure the poly lock version will work with stock covers but i ran the roller tip only style from comp cams, the magnums. They worked well on my L98. I didnt do anything to the push rods or the slots and not sure if they rubbed. Never checked. Did see some power gains. 8whp on a very lean tune. More tuning it should have picked up a good bit more. It wanted more fuel after the rockers. Air fuel dropped from mid 12's to 1 to low 14's to one and the only thing I changed was underdrive pulleys, injectors and rockers. Some of the air fuel difference I feel was from injectors not spraying the same even tho the chip was tuned for them.
jrdturbo
Mar 31, 2016 02:58 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
Night rider327
Sep 25, 2015 04:47 AM
