steering wheel is loose
Old Jan 14, 2012 | 12:24 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so i installed a NRG setup for my steering wheel and now the steering wheel is loose at the hub..i torqued the big nut down really well but its still loose..
noticed on another thread someone fixed this by putting the race around the bearing back into place..
Old Jan 14, 2012 | 11:59 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: steering wheel is loose
i didnt put the lock plate back on when i did it either..could that be it?? as it could be acting as a sort of spacer?
Old Jan 14, 2012 | 05:08 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you need the bearing race, preload cup, spring, cancel cam, lock plate and its retainer.
the lock plate cover isn't needed, but it looks better with it on.
Old Jan 15, 2012 | 12:03 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
no idea what any of that is except for the lock plate
Old Jan 15, 2012 | 01:11 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The lock plate holds the whole of the upper column together and pre-loads the bearings, without it the wheel will be really loose and you'll no doubt start shedding parts in no time... ie its a MUST.
Don't know that wheel in particular, but why did the lock plate need to come off to fit it?
Old Jan 15, 2012 | 01:20 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
it didnt i just didnt put it on but now im thinking i need to..gonna try it out tomorrow
Old Jan 15, 2012 | 02:44 AM
DENN_SHAH's Avatar
1 of these 2 links will help with the names of the parts,
http://www.chevyasylum.com/column/tiltcol.html
complete column break down,
http://www.diyfiero.com/dropspot/Jaz...ck_Rebuild.pdf
Old Jan 16, 2012 | 06:18 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Is it tilt steering? If it wobbles, it could be the four bolts that hold it together behind the main bearing in the colum. That's what was loose in mine. Tightened them up and it worked great.
Old Jan 16, 2012 | 10:13 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
just needed the lock plate behind the new hub thanks guys!
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
