Comon spots and fixes for gas tank leaks?
Old Jan 18, 2012 | 03:48 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
Found out back in the early fall that my 92 z has a leaky gas tank...but only when it's completely full and parked on a pretty steep incline. I'm going to be dropping it soon and putting in the racetronix fuel pump kit plus fix the leak. I've got a 88 tbi tank and a 86 lg4 tank in the garage if I need to use one. What are some of the normal spots these tanks leak an what do you guys do to fix them?
Old Jan 18, 2012 | 08:14 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Comon spots and fixes for gas tank leaks?
Mine was leaking exactly as you describe, full tank on a steep incline (my driveway). The leak is where the filler neck enters the tank, a common problem I gather from searching here.
It needs pulling and re-soldering, but for a temporary measure I managed to spooge some jb-weld-like epoxy around the offending area. It's held for several months now.
Old Jan 20, 2012 | 05:38 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
the filler neck where its attached to the tank, its all solid on these tanks in these cars
have it soldered at a radiator shop
our local radiator shop repairs fuel tanks all the time for cheap
Old Jan 20, 2012 | 03:41 PM
Screamin86's Avatar
Yeah after more research that what I've found. Thought about doing the recall thing but I'm gona be upgrading the pump and the car is in my garage sideways and on jack stands so I really don't feel like putting it together to go fight with a dealership over it. Almost thought about a 4th gen tank swap like I did in the trans am but then I'd have to deal with the fuel gauge and making new lines.
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
