Will this flywheel work?
Old Jan 21, 2012 | 01:58 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am trying to track down a vibration that my car has and I'm aiming towards the flywheel now. I just purchased a new flywheel and was wondering if this one will work or not.
Stroker Kit http://www.summitracing.com/parts/ESP-B12111030/
Balancer http://www.summitracing.com/parts/FLU-620101/
Flywheel http://www.summitracing.com/parts/MCL-460360/
The Mcleod flywheel is listed as being internally and externally balanced.
The current flywheel on my car is this one. http://www.summitracing.com/parts/NAL-14088650/
Is the current flywheel wrong, and will the new one work?
Old Jan 21, 2012 | 02:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Will this flywheel work?
Depends how your 383 was built.
Old Jan 21, 2012 | 03:44 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well the 383 was balanced internally and it has the internally balanced harmonic balancer, so should the Mcleod flywheel work?
Old Jan 21, 2012 | 04:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No.
It is listed as being suitable for use on INT and Ext balanced engines
As it comes
it is a NEUTRAL balance flywheel (correct for Int bal engine ) you can bolt weights to for use on Ext balance engine
Yes
You have a counterweighted flywheel on a Int balance engine where you should have a neutral balance flywheel
All SBC balancers are neutral balance ; only 400ci style cranks use a EXT balance balancer
There are no int balance balancers
Old Jan 21, 2012 | 08:17 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for clearing that up
BlackphantomZ28
Apr 24, 2016 08:14 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
KO1
Aug 31, 2015 06:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
sreZ28
Aug 14, 2015 07:48 PM
