305 Engine help!
Old Jan 22, 2012 | 05:41 PM
ChevyGuy565's Avatar
305 Engine help!
I have a 92 Camaro RS with a 305. Im trying to take the heads off and i have ran into a problem. The bracket that holds the power steering pump and alternator will not come off the head. All bolts are stripped. The 2 bolts going into the head and bolt going into the block itself is stripped. I have tried bolt grip sockets and they didnt fit, along with trying to drill them out but its to small of a space. Im thing of cutting it off or hammer it out but i dont know! Im truly stuck can anyone help me?!
Old Jan 22, 2012 | 08:25 PM
ex-x-fire's Avatar
Re: 305 Engine help!
The bolt heads are stripped? Do you know anyone w/ a welder? They can try welding larger nuts over the stripped heads.
Old Jan 22, 2012 | 08:50 PM
All the bolt heads are out but its the bolts that are holding on that bracket that are stripped. There T slot bolts size T-40 believe.
Old Jan 23, 2012 | 06:01 AM
ex-x-fire's Avatar
The nuts are off the studs? Can you double up nuts on the studs & try to turn them out.
Old Jan 23, 2012 | 08:36 AM
torque_is_good's Avatar
if original, the brackets are held on by large torx screws.
you will need room so out comes the radiator and associated hoses
I just pounded in the larger torx bit, connected my ratchet handle and was able to get mine. I of course tossed them and replaced with bolts
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
