Intake manifold gasket questions
Car: 87 IROC Z
Engine: 5.7
I'm replacing the intake manifold gaskets on my 5.7 TPI. I've got a couple of questions. I bought the Fel-Pro kit that has both the upper and lower intake gaskets.
Question 1. - When I did a test fit, I noticed the gap between the manifold and the block at the back is pretty big. The kit doesn't have a gasket for this. I have Permatex The Right Stuff gasket maker for this but it's going to be a pretty thick bead to fill the gap. Is this normal?
Question 2 - The kit came with 8 O rings. Where do they go? I didn't see any O rings when I took everything apart.
Steve
Steve
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Intake manifold gasket questions
#1 yes use rtv on the china wall, a little on the tips ot the gasket that touch the china wall both sides and I usually run a thin thin smear around the coolant ports on the intake gasket.
#2 injector o-rings just for the tips if you remove the fuel rail
Car: 1987 Trans Am
Engine: LQ9/L92
agree on the china walls; thick bead of the black rtv, let it set for a bit before putting the intake back on. its very easy to push it out of the way and have a big oil leak back there, so give it time to tack up a bit before reinstalling
ambainb
Apr 25, 2016 09:21 PM
