Wiring a 3 wire o2
Old Jan 31, 2012 | 06:55 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Wiring a 3 wire o2
I am trying to get my heated o2 sensor working. My problem is that it is wired into the wire for the fuel pump, but the fuse for the fuel pump always blows when I turn the key forward and can't figure out why. What else is a good place to wire it into? I havent found anywhere else yet.
Old Jan 31, 2012 | 07:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Wiring a 3 wire o2
What wires are connected where right now?
Old Jan 31, 2012 | 07:14 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The harness can only be connected one way. The 02 sensor wire has the connector on it to plug into the factory one. And the black wire is to ground and the pink wire is spliced into the fuel pump relay wire. However the fuse will always blow for the fuel pump, therefore the heater wont work for the o2.
Old Jan 31, 2012 | 09:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What application did this sensor come from?
Old Jan 31, 2012 | 10:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Its all brand new from tpi parts,
Sensor http://tpiparts.net/inc/sdetail/10956/15837
Harness http://tpiparts.net/inc/sdetail/2167
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
stalkier
Aug 21, 2015 01:54 AM
