viberation
Old Feb 2, 2012 | 09:33 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
viberation
Hey guys I have. 89 camaro with the 2.8 the engine is making a vibration at around 2500 rpm it is not a miss fire what could it be and please tell me its not internal
Old Feb 2, 2012 | 09:36 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: viberation
Does it get worse with higher RPMs? Bad harmonic balancers cause vibes, as do cracked flex plates. Hope you get an easy one.
Old Feb 2, 2012 | 09:39 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Re: viberation
Yes it does
Old Feb 3, 2012 | 03:47 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: viberation
How did the symptom occur? Was it progressive, or did it happen overnite? How's your oil pressure? (You're sure it's not ignition?).
Old Feb 5, 2012 | 01:39 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
Re: viberation
Yeah I'm sure it only does it when the belt is on
Old Feb 5, 2012 | 04:28 PM
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: viberation
Belt? What belt?
BlackTopKing
Jun 3, 2014 12:13 PM
evilemokid94
Interior Parts Wanted
Sep 26, 2013 09:58 PM
sgtconner
Jun 14, 2011 05:53 AM
Slow89Iroc-Z
Jul 27, 2003 06:16 PM
idrag2
Jan 6, 2003 07:02 PM
