will these valve springs work ?
Old Feb 3, 2012 | 08:53 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
http://www.ebay.com/itm/Z28-Valve-Sp...item1c21f93d44
i'm putting a lt4 hotcam in my 305 tbi rs . will these fit without any headwork ? what are the stock spring size ? thanks
Old Feb 3, 2012 | 09:31 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: will these valve springs work ?
anybody ?
Old Feb 3, 2012 | 12:52 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
no, the retainer will hit the guide. You need to run behive springs if you dont want head work. For a 305 tbi you're better off running an L98 cam and doing a motor swap later. .550 springs are too close to the .540 lift on that cam anyway.
Old Feb 3, 2012 | 05:01 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
do you know the part number for beehive springs ?
the lt4 hotcam lift is only .495 with 1.5 rockers an .528 with 1.6 rockers .
eventually i'll change the bottom end but for this summer i want to run a nice cam an turbo it . i may even switch to vortec heads . thanks for the reply
Old May 4, 2012 | 07:51 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
anybody else know of a spring i can run with a lt4 hotcam an do do no other head work ?
Old May 9, 2012 | 12:53 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
HEY ! ANYBODY ?
customblackbird
Aug 15, 2021 10:16 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Aug 12, 2015 07:08 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
