Back Firing
Old Feb 9, 2012 | 08:43 AM
blown-z's Avatar
Car: 1989 iroc-z
Engine: supercharged 305
Transmission: automatic
Back Firing
I installed larger fuel injectors on my camaro. It now backfires when i let off the gas and it runs sluggish. I was told i need to burn a new chip. And someone else told me i need a new distributor and wires. Any suggestions would be appreciated.
Old Feb 9, 2012 | 09:10 AM
88WS6GTA's Avatar
Re: Back Firing
Blown
Try southbay08 on this site. His specialty is injectors
Old Feb 9, 2012 | 09:12 AM
88WS6GTA's Avatar
Re: Back Firing
what psi did you have? What did you go to?
Old Feb 9, 2012 | 05:22 PM
blown-z's Avatar
Car: 1989 iroc-z
Re: Back Firing
I went up to 24 psi-Accel injectors
Old Feb 10, 2012 | 09:41 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Back Firing
The injector constant in your chip needs to match your injector flow rate.
Old Feb 10, 2012 | 12:48 PM
'84thunder's Avatar
Car: 1984 Camaro sport coupe
Engine: 5.0(H/O) 305 carb'd
Transmission: TCI St. Fitr stge 2 700r4 man.valve
Axle/Gears: stock gears, Limited Slip
Re: Back Firing
just throwin my in....check ur whole entire exhaust system headers to collectors to muff for any leaks. u would be surprised that any slight leak up by the headers will cause backfiring like a shot gun sound or rapid crackling.
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
justin57
Aug 20, 2015 07:05 PM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
