Weird starting problem that just started.
Old Feb 12, 2012 | 02:13 PM
TkernIROC1986's Avatar
Car: 1986 IROC-Z
Engine: 5.7L TPI L98 350
Transmission: 700R4 Auto
Axle/Gears: 10-Bolt Posi Disc 3.73s
I have an 86 IROC that I put a new 350 in. When I start it up for the first time, it starts no problem and fires right up. If I drive around for awhile and shut it off, it won't start, it will crank over but will not fire. If I let it sit for 5-10 minutes it will fire right up. I'm not sure if this might be a starter problem. Any suggestions, cuz this is a pain when I drive down the street to fill up and I have wait to start my car. Thanks for your help.
Old Feb 12, 2012 | 02:25 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: Weird starting problem that just started.
Originally Posted by TkernIROC1986
I it will crank over but will not fire.
If you got crank, starter should be find. Sounds like a fuel issue. When mine did the same thing turned out to be the "Fuel pump relay". Luckily it was that and not the pump........
Old Feb 12, 2012 | 02:30 PM
Car: 1986 IROC-Z
So why waiting the 5-10 minutes, it will fire right up? It's getting fuel, it's just got that sluggish crank when it first does it, the I wait and it fires right up.
Old Feb 12, 2012 | 02:54 PM
You didn't say sluggish crank at first... When it's running what's your volt meter showing?
Old Feb 12, 2012 | 02:58 PM
Car: 1986 IROC-Z
Showing normal range right around 13-14.
Old Feb 12, 2012 | 05:01 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
You might have to insulate your starter from exhaust heat, what are you running headers or what.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
apo_bailon15
Mar 28, 2016 05:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
