Vacuum guage fluctuates
Old Feb 13, 2012 | 06:41 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Ok so I just got my top-end back together and in the car. Its a 388 with a lopey cam (240/246 @.050") and the vacuum gauge fluctuates between 7" and 9" of vacuum. I assume this is normal for this cam. All the lifters look perfect and the lobes all had the same amount of lift (eye balling.)
I just wanted to make sure this is normal for a large cam.
I think I got the valve lash set correctly at least seems right.
Old Feb 13, 2012 | 06:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Vacuum guage fluctuates
Idle vacuum? What speed and how much advance?
Old Feb 13, 2012 | 07:11 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Right now base timing is 16* and 900 rpms mechanical doesn't kick in until 2900.
Old Feb 14, 2012 | 09:19 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You mean mechanical is fully in by 2900?
How is the vacuum advance set up?
Old Feb 14, 2012 | 02:30 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Yeah, that sounds about right for that cam.
You might be able to increase that a little and get it a little more steady if you use an adjustable vacuum advance unit on your distributor so that you get another 10* advance or so at idle.
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
