Problem with Vortec intake gaskets
Old Feb 15, 2012 | 12:21 AM
morgsie's Avatar
Hey guys, having a bit of trouble with my intake gaskets that I am using on my Vortec headed L05. I ordered a set of Felpro MS901312 from Summit and as you can see from the pictures below, they don't quite line up between the intake runners. Should I take a heat gun and carfully try to move the middle piece between the runners? Should I just run it "as is"? Should I try to get another set (already had to wait 3 weeks from Summit to get these in)? I also have a set of Felpro 1255's, but I heard they weren't as good...
Also, in the last picture you can see one of my water ports, there is a gouge in it left from the previous intake gaskets that I can feel with my finger nail. Should I use a bit of RTV around here with either the MS901312's or 1255's or just run em dry. FWIW, no insructions came with the MS901312.
Thanks.
Attached Thumbnails Problem with Vortec intake gaskets-dscf2544-large-.jpg   Problem with Vortec intake gaskets-dscf2545-large-.jpg   Problem with Vortec intake gaskets-dscf2540-large-.jpg
Old Feb 15, 2012 | 10:03 AM
morgsie's Avatar
Re: Problem with Vortec intake gaskets
BTW, I am running an Edelbrock Performer RPM (non-airgap).
Old Feb 16, 2012 | 12:06 AM
morgsie's Avatar
anyone?
Old Feb 16, 2012 | 08:10 AM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
I put the GM performance vortec gaskets on mine and they fit just about the same. and I just installed them. I also used a thin skim coat of RTV around the water ports. If I remember correctly my blazers 4.3 which has similar style gaskets and vortec heads had the same issue. and I noticed no difference before and after fixing the intake gaskets.
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
