Smog pump delete
Old Feb 22, 2012 | 06:29 PM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
Smog pump delete
I believe my smog pump might be going out. I have started to have a bad sound coming from either my air compressor or smog pump. But dont honestly know. I just know it varies with the speed of the engine. My big question is after i get it off, will i have to plug anything, or can i just pull it right off and just reroute the belt? And would anyone have a belt number i would use? I have looked through out the forums for other posts, but didnt know if i would have to plug something after it comes off. o.O
90 305 tbi
Old Feb 22, 2012 | 10:45 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Smog pump delete
You might check the Catalytic converter first. If you remove the air pump, just be sure emissions won't be an issue.
Old Feb 22, 2012 | 10:57 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Camaro RS
will i have to plug anything,i
you need to seal where the air lines go into the exh manifolds
rubber cap on the one way valves or remove the valve altogether and use a pipe cap on the threaded pipe fitting
remove line to cat and seal cat pipe
https://www.thirdgen.org/forums/faq-...lete-smog.html
Old Feb 23, 2012 | 05:21 AM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
thanks for help.
and to help define that its really the smog pump, its rather loud on a cold start, but after a min or 2 its not a loud, but still the sound still changes with the speed of the engine.
Old Feb 23, 2012 | 10:15 PM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
bump
Old Dec 10, 2015 | 10:13 PM
gnilson's Avatar
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
So my AIR pump went bad and I removed it. Do I have to remove anything or block off anything like the pipe attached to the pump? I just want to get it running for the time being. I will strip everything off later.
TIA
Geoff
Old Dec 11, 2015 | 08:29 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
this exactly,
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
