need help built 355
Old Feb 24, 2012 | 08:18 PM
bigals84ta's Avatar
need help built 355
got an 84 ta from grandpa been sitting 8 years got home ok but now running terrible backfire through carb and sounds like vacuum from dist but dont see anything leaks black plugs where do i start plugs ? carb? dis?
Old Feb 24, 2012 | 09:08 PM
ex-x-fire's Avatar
Re: need help built 355
Tune up, fix vacuum leaks, replace filters, fresh gas, oil,set timing,ect..
Old Feb 24, 2012 | 09:21 PM
bigals84ta's Avatar
do you no what timing should be and when you say tune up plugs, wires, oil ,and what else
Old Feb 24, 2012 | 09:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Major service.
Check everything is 100% , many things to get rotten or corrode with age
Replace as needed
Old Feb 24, 2012 | 09:49 PM
bigals84ta's Avatar
But ran good to get home
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
6998poncho
Sep 25, 2015 02:56 PM
