wierd sound from back.
Old Feb 24, 2012 | 09:32 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
I get a grinding kind of sound sometimes coming from the back end of the car.mostly when under a slow increasing load.dose that make sence?Like on a slow take off at about 10mph I step on the gas just a little harder or start going up a hill at 40ish and give a little extra gas to keep my speed.sounds like the rearend.But its not doing it all the time.At 55 to 65 runs super!Could it be my rearend or just spark knock.It's not running at 100%.I started to put 93 octain gas in it.hope it helps.OH,it's a 5.7tpi in a 89iroc auto.Ideals at 1000 to 1200 not so steady.
Old Feb 25, 2012 | 09:24 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: wierd sound from back.
Could be a rear wheel bearing or low gear oil in the differential. Have you checked the level?
Old Feb 26, 2012 | 04:13 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
checked it and added about an inch.well see if that dose it.
Old Feb 27, 2012 | 09:59 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
it's doing much better.still some noise when medium acceleration is given.but if I take my time or take off fast theres no grinding at all.My wife thinks it might be the muffler.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
lanceflame44
Sep 25, 2015 12:28 PM
