Removing Power Steering
Old Feb 26, 2012 | 12:17 PM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
I'm thinking about removing my power steering, have any of you removed yours? What should i expect as to handling?
Old Feb 26, 2012 | 02:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Removing Power Steering
As long as you don't use wide front tires, you probably won't notice any difference. Don't use a small steering wheel and expect to turn the wheel a little more in parking lots.
Old Feb 26, 2012 | 05:29 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Mine gets 'removed' sometimes if I drive thru a large enough puddle, and the belt gets wet. Makes the car nearly un-steerable, scary if halfway thru a turn. I do have 8" rubber up front tho.
Old Feb 26, 2012 | 08:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
There's a big difference between no power assist and manual steering. You can't compare the two of them. A manual steering box is designed to work with only mechanical leverage. A power steering box needs the hydraulic pressure.
Old Feb 27, 2012 | 04:06 PM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
I do know that you have to reroute the hoses otherwise your manually working the pump. I have a 92 Integra that doesn't have power steering and its pretty easy to turn, but yea when you just take the belt off its going to be very hard to turn. Also not rerouting the hoses will destroy your pump, but then again removing your power steering is different in every car.
I was more so wondering if anyone on here has done it completely, not just taking the belt off.
Old Feb 27, 2012 | 07:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Many of us here have swapped our power-steering boxes for manual boxes.
The manual boxes from a Chevy Monza, Vega, or S10 pickup will work in an F-body.
You can also pay more and get a new manual box from a few sources online.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
