knock pig sensor
Car: 90 iroc z
Transmission: 4 speed with od
Axle/Gears: 323 ratio
knock pig sensor
Knock ping sensor is going off when i get n it really hard!timing is correct at 6.d !so is ok for the sensor to go off r knock?any ideas
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: knock pig sensor
how do you know?
are you datalogging?
It is going off because it is detecting knock ;
could be bad fuel
Sensor itself may be faulty
A datalog will tell exactly what is going on with engine
could be bad fuel
FormulasOnly
Sep 10, 2015 09:07 PM
