1986 305 rocker questions
Old Mar 1, 2012 | 08:54 PM
phaller13's Avatar
Just a quick question 1986 tpi motor with stock heads are those self aligning rockers or not, just wondering because i have a set of roller tipped rockers but there for vortec heads off a 350. So really just wondering if they would work. Thanks
Old Mar 1, 2012 | 09:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 1986 305 rocker questions
If the ones on your engine look like this they are self aligning
Note the " ears" that locate the rocker to the valve stem
Old Mar 1, 2012 | 09:43 PM
phaller13's Avatar
Thanks for the help and quick response
Old Mar 2, 2012 | 06:28 AM
Look also at the heads: where the push rods come through them, if the holes are narrow slots that fit tight to the push rods, then you CANNOT use SA rockers.
A motor from 86 would not have come with SA rockers. If they use perimeter-bolt valve covers (what 86 heads would have come with), then they almost certainly are not.
Reborn756
Sep 4, 2015 03:42 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
