whats your opinion?
Car: 88 Camaro
Engine: 5.0
Transmission: 700r4w/shift kit
Axle/Gears: 10 bolt
whats your opinion?
i am getting ready to swap from tbi to carb i already have a holley 600 vacuum secondary carb and getting ready to or a dual plane intake but i am wanting to put a cam in it and was just wanting to know if i can put in a cam with the motor still in the car also what do you all think about this cam Hydraulic Flat Tappet, Advertised Duration 280/290, Lift .443/.465 i want to make a little more power and torque and maybe a little thump thanks for any help
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: whats your opinion?
Cam should work ok with stock heads. Yes you can change cam with engine in car, but radiator and A/C have to come out. Best to get someone experienced to supervise if your first cam swap.
Don't forget to get a good quality distributor with both mechanical and vacuum advance. The distributor gear needs to match your cam gear.
Car: 1988 Iroc-Z Black w/ blue/silver
Engine: L98 5.7
Transmission: 700R4 (obviously)
Axle/Gears: BW 9-bolt 2.77
If your car is an 88' shouldnt you be looking for a roller cam rather than a flat tappet?
Car: 87 iroc-z
Engine: 454
Transmission: th350
+1 Vega. also, in my opinion, that cam is too big for a stock converter. if going to a carb, get a fuel pressure regulator. do you plan on getting a different ignition, like h.e.i.? not too sure the computer would be able to work with a cam that big?
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
skinny z
Oct 5, 2015 06:23 PM
