89 Firebird cranks but will not stay running for more than a few seconds
Old Mar 10, 2012 | 07:18 PM
jcoinster's Avatar
I bought a Firebird for dirt cheap from a relative and it was working fine before he had it sitting for 3 years. Unfortunately, he didnt start it every so often and only kept it covered, and so the car wont start, as anyone would expect.
All the electronics work in the car, we replaced the starter, battery, and the fuel pump (which wouldnt turn on when we took it out - the new one clearly does), since there was no fuel getting to the carburetor. We also replaced the fuel relay switch. The car sounds good once we spray starting fluid into the carburetor.
I've been told it could be the VATS, but the car sounds like it's a normal start until it kills 3 seconds in. Then again, that could be because we're spraying into it.
Any help would be greatly appreciated!
Old Mar 10, 2012 | 07:26 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
Re: 89 Firebird cranks but will not stay running for more than a few seconds
sounds like the same problem that were having with an s10 im gonna keep watch and ill tell you if we can find out on it, (so far our speculation iis clogged fuel filter)
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Sherpajames
Aug 7, 2015 06:56 PM
