modified MAF and now running bad
Old Mar 13, 2012 | 07:57 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hi guys
i modified my MAF last week cutting it up and putting it into a 3.5 incs tube on a cold air intake. really happy with how its all worked out but when u fire the car up the idles bad tends to jump around a bit and some times stalls. if u give it a little rev shes bogs down and back fires down the intake. haven't done anything with the timing but sounds like the timing is of.
out on the road shes seems fine really only ones in a while only if i putting my foot down she will bog down but soon pick back up.
any ideas any one????
does seem to be getting better the more i go out in her, so could it just be the computer learning the new air intake
thanks guys
Old Mar 13, 2012 | 08:07 PM
Twin_Turbo's Avatar
Re: modified MAF and now running bad
it's running lean because the maf will register less flow than there is because of your larger pipe. Needs tuning.
Old Mar 13, 2012 | 08:11 PM
Car: 89 gta
get it on a dyno??
Old Mar 13, 2012 | 08:53 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Needs PROM tuning, either on dyno rollers or just by driving, datalogging & tuning.
Old Mar 13, 2012 | 09:49 PM
Car: 89 gta
thanks man i thought i would just need to learn
Old Apr 3, 2012 | 04:07 PM
Car: 89 gta
still running bad guys
played around with the timing advanced her by 2 degrees and altered the idle. shes running better when hot but in till then she stumbles when driving at a constant speed and stalls a lot when at low speeds like reversing.
i did disconcert the maf and she seems to run a lot better but dint go out for a drive just moved her up and down the drive.
any more ideas guys???
Old Apr 3, 2012 | 05:43 PM
conlinj's Avatar
It needs prom tuning, the MAF tables will have to be adjusted.
Old Apr 3, 2012 | 05:54 PM
Car: 89 gta
can this been done just by driving the car or???
Old Apr 3, 2012 | 07:10 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
no. Is it the car you have listed under your name? You have a supercharger on the car? How was it tuned for that?
Not to sound rude but if you have to ask this question then jumping into tuning might be a steep learning cure for ya. Or you might catch on quick. With that said here is a good start for you to read.
https://www.thirdgen.org/forums/diy-...uide-book.html
Old Apr 3, 2012 | 07:11 PM
conlinj's Avatar
No you have to have a custom chip burned for the ecu
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
