Distributor Condenser (Capacitor)
Old Mar 19, 2012 | 03:46 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Got a tricky one for you dudes.
Does anyone know what a suitable replacement condenser (The little capacitor under the rotor) would be? I see a bunch on ebay but they are for older 70s and down style cars.
I don't see why I COULDN'T use a condenser from a 2nd gen camaro as they also had HEI, but the question is would the microfarad rating of the capacitor vary from a 2nd gen to an 85 LB9?
http://www.ebay.com/itm/Camaro-Fireb...item1e65d54e7a
Old Mar 19, 2012 | 04:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Distributor Condenser (Capacitor)
Those are points condensers.
Why do you want to replace it?
Old Mar 19, 2012 | 04:29 PM
Car: 1985 Z28
That's the part I don't understand. I was reading that the job of the condenser is to prevent a voltage spike when the points open. What is the purpose of having one in an HEI distributor?
I figured being (Most likely) 27 years old It's only $10 so while I have the distributor out why not?
Old Mar 19, 2012 | 04:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In HEI it's an RF noise filter. Completely different purpose than in a points system.
Standard Motor Products RC-3, if you really need it. You'd never know it was changed, unless maybe you listen to a lot of AM radio.
Old Mar 19, 2012 | 04:37 PM
Car: 1985 Z28
Thanks for saving me the $10
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
