What goes to this sensor?
Car: 1989 Camaro Iroc Z28
Axle/Gears: Borg Warner 9-Bolt/ 2.77
I found an unhooked sensor on the plastic air piece, what is it for? I cannot find a loose sensor wire anywhere. Some one told me its for an ambient temperature sensor, but did a 1989 camaro with a stock L98 come with one? I already have a MAF sensor for the air.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: What goes to this sensor?
That's the IAT or intake air temp sensor. Not sure where the plug comes from on yours though.
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
It's in the wiring diagram. Should be a plug with a tan and a black wire. Might be plugged in to a sensor that's been moved or it would set off the SES light wouldn't it?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
From the factory the IAT / MAT sensor was under the plenum between the runners and had a 2 wire plug coming out of the main harness on firewall.
To be fitted where yours is now , PO would have had to make or buy the extension harness to connect to that plug
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
This is probably a newer (91-92) intake that has replaced your original and the sensor was left there to keep the hole plugged. look under your drivers side plenum and you should see the same sensor screwed in under neath with a plug in it.
I think all TPI had it in plenum but moving the IAT sensor to the plastic air intake is a common trick. It senses cooler air there and provides minimal performance enhancement.
Interesting, that may be a reason why the previous owner may of taken this from another camaro.
Mystery solved, I found the IAT sensor underneath the front of the plenum. I tried to see if it the wire would reach the plastic intake sensor, but it's too short. Thank you all for the help, now I feel relived.
Car: 82 Z28
Transmission: T400
Engine: 4++,350 & 305 CIs
All TPIs use a MAT sensor (manifold air temp) in the manifold
V6 and TTA turbo V6 used a IAT (intake air temp) in the intake plastics
the plastic Y pipe you have is a replacement from a V6 car. (not a big deal unless your doing a 100% resto)
Car: 82 Z28
Transmission: T400
your kidding me, the connectors look almost identical. Now i am going to have to pull apart the nest between the runners.
I found it, it's underneath the bottom of the back of the plenum.
Car: '02 Z06
Engine: L33 5.7
The connectors ARE identical. The sensor is basically a universal thermal sensor. All its purpose is to read the temperature its screwed into whether its air or water. I use the same sensor x2 with my aftermarket efi for the same purpose.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
TPI cars have a plug there where v6 cars have a sensor there.maybe some PO played mix n match?
Car: 87 camaro at the moment
Engine: carbed 305
Transmission: 4 speed automatic
can someone please help me with what these sensors are in the pic its sideway but its the top sensor it has a grey nipple on the top looks like its for a vacumn line and its got a broken spot for a two wire plug i have the wires and plug but i cant find out what the sensor is and the second sensor is the one thats located on the botton of the front of the intake manifold the top is broken off it looks like it had a metal prong conneted to the top of it i have the prong part of it but the sensor i broken in two and i cant find out what senor it is it looks blue in the pic right above the hose
well i thought i was going to upload a pic but i cant seem to do so
Engine: carbed 305
i think i got the pic to post
i straightened the pic its now the one on the right and the blue colored one at the botton left
pleae help its a 87 camaro with a 305 carbed 4 barrel
HoosierinWA
Oct 7, 2015 10:15 AM
