Just got my 86 TA, Code 36
Old Mar 23, 2012 | 07:09 PM
kosmos753's Avatar
Car: 1986 Trans Am
Engine: 5.0 TPI swapped in a 5.7 block
Axle/Gears: 2.77
Noticed when i got my 86 TA that it had two codes set. 36, and 42. code 42 was just a chewed wire, i hate squirrels, and i have been trying to find the cause of the code 36.
i have replaced both relays as well as the terminals in the relay connectors for the MAF, and Burn off circuit. I grounded the burn off relay, with the MAF unhooked and engine off, and had battery voltage at the MAF connector. but when i checked with the computer grounding it i only got 4 volts at most. herd the relay activate for about 1 to 2 seconds. the hot wire did not glow at all. and i had a MAF reference signal of 2 volts during the burn off cycle.
Found out that the relays were mixed up.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
