What the $%&#@ is this??
Old Mar 25, 2012 | 11:08 PM
zzjakect's Avatar
Car: 1985 Z28
This is located on passenger side of engine. Mostly just hanging, but connected with a vacuum?? hose? What is it and how do I reinstall it or eliminate it? 1985 Z28 with a 350.
Thanks for your jelp.
Old Mar 25, 2012 | 11:17 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: What the $%&#@ is this??
That is the egr vacuum solenoid, the vacuum signal starts from the port under the throttlebody to the solenoid to the egr valve.
Old Mar 25, 2012 | 11:19 PM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
Old Mar 26, 2012 | 12:34 AM
zzjakect's Avatar
Car: 1985 Z28
where is it normally mounted and what should be connected to it.
Old Mar 26, 2012 | 11:20 AM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
It is loacted on the passenger side, near the rear of the motor. One vacuum line goes to the underside of the throttle body and one to the EGR valve.
