needing some help
Old Mar 26, 2012 | 11:21 AM
gsp132's Avatar
needing some help
I've been working on a 1985 Camaro 5.0 tpi auto. So far I've put on intake gaskets, iac and an egr valve and it's running good now except for when you first start it up it will idle at about 1500 rpm's and will not slow down until you put it in gear and drive it about 40 to 50 ft then it will idle down to where it should be. It doesn't make a difference if you let it idle for that distance or if you give a little gas. If you let it set and idle for a while after it warms up it will then repeat the above process. I don't know if it does this before Thanks in advance for any help.
Old Mar 27, 2012 | 02:17 AM
87camaro iroc-z's Avatar
Car: Camaro z28 Iroc
Transmission: a/t
Re: needing some help
I have got the same problem. After a couple of months working on the car i started it yesterday. No codes but idle at 1500 rpm. The car is also a 5.0 tpi. Maybe this occurs because the ecm is reseted.
Old Mar 31, 2012 | 12:44 PM
gsp132's Avatar
87 camaro iroc-z I adjusted my tps and problem went away. You might give it a try.
Old Apr 6, 2012 | 06:27 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
if ur car is below a 1990 then u need to properly set your IAC AND TPS https://www.thirdgen.org/tpimod2S.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
