Disconnecting FP oil switch
Old Mar 26, 2012 | 04:12 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Would there be any negative side effects to disconnecting the harness that powers the fuel pump via the oil pressure switch at the back of the block?
I want to install a sending unit for my aftermarket oil pressure gauge however the port at the front of the block does not have enough clearance.
I am under the impression that the only problem that could arise from disconnecting this switch is I would be stranded in the event of a FP relay failure. Someone correct me if I'm wrong.
Old Mar 26, 2012 | 05:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Disconnecting FP oil switch
Old Mar 26, 2012 | 06:42 PM
Car: 1985 Z28
Originally Posted by vetteoz
Thanks man. Good reason to toss a spare in the trunk.
Old Mar 26, 2012 | 07:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Won't help if you loose the control (ECM ) side of the relay.
Seems to be a common complaint with age
Leave the switch plug accessible and carry a jumper so you can hot wire the OP switch
so you can run the pump to get home
89GTAOz
May 16, 2020 09:31 AM
mddaniel
Sep 8, 2015 05:16 PM
Slush92RS
Sep 2, 2015 08:56 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
