Fuel Problem
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Fuel Problem
Hi there.... i just got done putting in my engine... 3-5 TBI 5 speed.. so it started the first 4 times... then it didn't .. im guessing its the fuel pump so i need to check it because i don't hear it at all.. i checked the oil pressure sensor next to the oil filter and i read that this kicks in the fuel pump if the relay goes bad... also im thinking about changing the fuel filter.. it might be cloged for it might be the original for all i know.. also i tried to check some relays or fuses.. i cheked the one near the battery but that was good... but i found this one missing
is that for the A/C or fuel pump?
Engine: 305 TBI
Re: Fuel Problem
bump..... so the pump works when i connect it to the g ADL.... now i unconnect the fuel from the tbi and i start the pump... i only get a small leak.. so i changed my fuel filter.... still same issue.. i think that the fuel pump inside the tank is cloged up... this happened when i pored new gas.. wich i hadnt for the past 8 months almost... anyone?
Engine: 305 TBI
Re: Fuel Problem
Ok so update... Theres fuel to the tbi... But the injectors arents spitting :/ bad wiering? Bad fuse? Plase anyone
Engine: 4++,350 & 305 CIs
Re: Fuel Problem
check fuses.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
