89 Trans Am Fuel Pump Problem
Car: 89 Trans Am
Engine: 305 V8 TPI
Transmission: 700R
Axle/Gears: 308 Eaton Posi
My 89 Trans Am just wouldn't start after coming out of Quick Check to buy an Almond Joy.
The engine turns over, but just won't start. I don't smell gas when it turns and doesn't ignite, and when I cycle the key, I don't hear the fuel pump like normal, leading me to believe that either the fuel pump is bad or isn't getting power. However, the fuel pump is about 5 years old, and I haven't heard of fuel pumps commonly malfunctioning that quickly. How can I check this? Is it possible to check without going directly to the pump itself? Also, is there anything else I should check to see what the problem might be? Thanks! : )
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 Trans Am Fuel Pump Problem
start witch checking the fuel pump relay.
Engine: Lb9
Transmission: M20
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
