general guestion about tdc piston 1 and vavles
Old Mar 29, 2012 | 12:45 PM
cactusman92's Avatar
Car: 1991 Chevrolet Camaro Z/28 (Project
Engine: 5.0L 305
Transmission: 700R4 W/ B&M shift kit
how should the valves be aligned at TDC on piston 1. should any of the other valves be open and closed on the same side or should they appear to be lined up with all of them appearing closed? If you need a detailed explanation just let me know what you need to know. Motor is a 305
Old Mar 29, 2012 | 12:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: general guestion about tdc piston 1 and vavles
The other valves will be in all kinds of positions both times that #1 is at TDC.
Old Mar 29, 2012 | 12:59 PM
Engine: 5.0L 305
Its been a while since ive had the engine apart the only thing i remeber is on one of the tdc strokes either the 6 or 1 the driver side apeared to be all lined up while the other side had some up and some down at least a noticeable amount which should the tdc on piston 1 look like all apearing lined up or the other ones abvious they are open and closed
Old Mar 29, 2012 | 05:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You ONLY look at the valves for cylinder #1. What the other valves on that bank, or the other bank, look like is irrelevant.
To be precise, you should be watching the valves as you are approaching TDC - neither should be moving as the timing mark approaches the timing tab. At TDC, it could appear that both valves are closed when in fact the exhaust has just closed and the intake is about to open - that's why it's important to watch them as you turn the engine over to TDC for the #1 firing position.
Old Mar 29, 2012 | 08:12 PM
Damon's Avatar
What five7kid said. Remember there are TWO Top Dead Centers for each cylinder. TDC of the compression stroke (both valves closed for a considerable period both before and after TDC) and TDC of the exhaust stroke (the "overlap" period of the cam when both valves are still slightly off their seats- exhaust almost closed, intake just begun to open).
Old Mar 30, 2012 | 03:48 AM
Alain2's Avatar
Car: 1991 Z28
Engine: 5.0
On my 305 TPI, when in tdc piston 1, the following valves are close:
exhaust 1,3,4,8
intake: 1,2,5,7
When tdc piston 6:
exhaust: 2,5,6,7
intake: 3,4,6,8
Pac J
May 17, 2020 10:44 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
