which cylinder heads should i use?
Old Mar 29, 2012 | 09:54 PM
hondorian7's Avatar
Car: 91 Chevy Camaro RS
Engine: 305 TBI
ok so i have two sets of heads one set is out of my 91, 305 TBI and the second set is from an 84, 305 carb. I was wondering which set would be best to rebuild i dont know much at all about cylinder heads so any information will be helpfull.
Old Mar 30, 2012 | 02:36 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: which cylinder heads should i use?
Post up the casting numbers off each
Old Mar 30, 2012 | 05:21 PM
hondorian7's Avatar
Engine: 305 TBI
14014416 and 14102187
Thanks!
Old Mar 30, 2012 | 10:02 PM
Chainlynk's Avatar
Do you want to have a carburetor or fuel injection? Gm changed the heads and intake manifolds back in the 80's so that you had to use carb heads with a carburetor and fuel injected heads with fuel injection. They changed the angles or some such. So those carb heads can be used with any small block chevrolet intake manifold that has a carb on it. Your fuel injected heads can be used with most fuel injection systems such as tbi, cross fire, tpi and I believe sequential. Both heads are probably very similar 194 intake 150 exhaust and coming on 305's probably small chambers like 58cc. no good for high compression flat tops or anything. You can get intake manifold's that accept carburetors but are designed for fuel injected heads, but why waste the money? It really depends on what your planning on doing.
Old Mar 30, 2012 | 10:16 PM
hondorian7's Avatar
Engine: 305 TBI
Thank you fot the information.... im not really sure which way i want to go im thinking carb cause i have a new cam and intake manifold for the carb engine
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
