89 rs stumbles and dies when starting
Old Apr 1, 2012 | 12:48 PM
88BlackBirdGTA's Avatar
Car: 88 Firebird Trans Am GTA
Engine: 350tpi w/383 setup
Transmission: TH350
Axle/Gears: Stock possibly?
Ok, a friend of mine bought a car about a month or so ago, and it ran fine at the time and for a while. It's an 89 rs. Orriginal 700r4 tranny(as far as I know) but supposedly the motor is now a 350 tbi out of a 91 corvette instead of the 305 v8 that was offered. I don't remember gm offering a tbi in the c4 vettes tho. Unless they changed the intake over to it when installing. but anyway, the problem...when started up it'll stumble and die multiple times. I have to rev it up to keep it running. And then the rpm's will just jump around to where it nearly dies but jump back up. It'll do this for several minutes. Then once I start to drive it, it'll kinda lag out a bit but then run fine. It will idle relatively high tho. About 3500 or so. After some more driving tho it sometimes goes down to around normal. Possibly a fuel problem with the injector? Or a throttle solenoid/positioning type sensor?
Old Apr 1, 2012 | 06:24 PM
Transmission: TH350
Re: 89 rs stumbles and dies when starting
Any ideas at all? Much appreciated
Old Apr 1, 2012 | 07:53 PM
Jesse Boggess's Avatar
Car: 1992 Camaro RS
Engine: '78 L82 bored .30 over
having the same issue with my 92 rs. Do you also experience white smoke and gas fumes?
Old Apr 1, 2012 | 08:00 PM
Transmission: TH350
No fuel smell that I'm aware of. But I believe there's a little smoke out the pipes when I get on it to keep it running. Other than that nope
Old May 10, 2012 | 11:32 AM
NinjaIzuna's Avatar
I have this same issue with an 89 camaro rs with the 2.6 v6. I believe its the Throttle positioning sensor. When I purchased it it looks like it was cut at the connector.
https://i.imgur.com/maq0o.jpg
https://i.imgur.com/fAeWC.jpg
What I did to get it running even with this issue is I adjusted the throttling screw to throttle higher to prevent the stalling and not have to rev the engine. However this is only a temp fix and I suggest you pick up a new connector and test the Sensor its self.
Old May 10, 2012 | 11:49 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Of course, before replacing any sensor, test it. The TPS receives a 5v reference and ground from the ECM and returns a voltage signal between .5 at closed throttle to 4.5 at WOT. Use a voltmeter to test between pin B and ground while you slowly move the throttle from closed to open. The voltage should change smoothly with no glitches or drop outs.
Honestly though, your problem sounds very little like a TPS issue and more like a coolant temp sensor issue. The CTS is the two wire(yellow wire, black wire) sensor at the front of the intake manifold. You can test it for resistance. It should read about 3,400 ohms at 70 degrees(cold engine) and about 180 ohms at 220 degrees(hot engine).
Old May 10, 2012 | 11:02 PM
newagereject's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.73 posi
Try looking at your idle air control as well, if it does not move freely in your hand then its shot
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
EFR2000
Aug 18, 2015 08:54 PM
Winchester1094
Aug 18, 2015 10:23 AM
