Cross reference on fuel tank?
Old Apr 2, 2012 | 10:44 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
This may be a silly question, but are there any fuel tanks besides what came in the 82-92 Camaros/Firebirds that will work in a 87 GTA with the 5.7 TPI? Also, is it possible to use a tank from a V6 car? Thanks for any help.
Old Apr 3, 2012 | 04:12 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Cross reference on fuel tank?
Except for some fuel cells I do not know of any other tank that will fit. Any other tank would require modifications to make work including fuel cells. However a V6 tank is the same a a V8 tank and can be used just by changing the fuel pump. (I have heard that the V6 pump is supposed to be the first step up in pumps for the V8's but I doubt that.) I would reuse my original one or buy another proper pump. Either way the fuel injected sending units are the same just a different fuel pump. I believe that even the carbed tanks will work with a fuel injected sending unit put in place.
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
