questions about cut lines on 350 vortec
Old Apr 5, 2012 | 11:55 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i just brought home a 5.7 vortec out of a 96 suburban today and these lines were cut, can anyone tell me what they go too? theyre coming from the oil filter housing.
Old Apr 6, 2012 | 06:50 AM
ex-x-fire's Avatar
Re: questions about cut lines on 350 vortec
They obviously go to the oil filer cooler adaptor. You can remove that & use a standard filter mount. Do you have any sbc cores around? If you do, then swap over.
Old Apr 6, 2012 | 08:56 AM
Engine: L31 350
Is it a hard swap?
Old Apr 6, 2012 | 05:58 PM
ex-x-fire's Avatar
No, its not hard to swap over, just remove the adaptor, usally 2 bolts hold it on. The standard type adaptor fit inside the oil filter mounting base, its the middle part in the picture.
Attached Thumbnails questions about cut lines on 350 vortec-imagescagg2y2j.jpg
Old Apr 6, 2012 | 06:08 PM
Yup, just do away with the oil warmer... get a standard oil filter piece that doesn't use the warmer, like maybe off of your existing engine... leave that whole part of the car like your current car, not like the truck that the motor came out of.
Old Apr 6, 2012 | 10:18 PM
Engine: L31 350
can i use the v6 adapter? and also sofa i dont understand what your saying on the last sentence "leave that whole part of the car like your current car, not like the truck that the motor came out of." can you explain please?
and what do i do with the 2 holes on the side of the housing?
Old Apr 6, 2012 | 10:25 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
That goofy oil warmer/cooler whatever it is can be removed and setup just like any regular sbc. Dont worry about it. Just get an oil filter mount and call it a day.
Old Apr 6, 2012 | 10:28 PM
Engine: L31 350
so just unbolt the old one and re install the new? do i need any new gaskets or anything? can i get this part from autozone?
Old Apr 6, 2012 | 10:30 PM
Engine: L31 350
i still dont understand what i do about the holes that the lines went into, wont they leak if they arent plugged?
Old Apr 7, 2012 | 07:31 AM
ex-x-fire's Avatar
Your removing them. When its all done it'll look like the picture I put up.
I do't know if a v6 (which one?) will work, I know the 4.3Ls had smaller filters the sbc.
Old Apr 7, 2012 | 08:16 AM
Oh sorry, didn't realize you currently have a 6-cyl...
In that case, I haven't the vaguest dimmest foggiest hint of a glimpse of a whiff of a clue what your oil filter setup is like because I've never seen one. But assuming it doesn't include an oil warmer like the truck motor has, it probably has a place the oil filter kind of screws up onto the block; you need to get the corresponding parts off of a V8 car or truck somewhere WITHOUT the oil warmer if your 6-cyl parts won't unbolt and re-bolt to the V8, and put those on your new motor, such that the filter just screws up onto the block the same way it does on your 6-cyl. That sandwich adapter thing and those lines will all go away.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
