High Idle...Please help!!
Old Apr 6, 2012 | 01:58 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So I got a 84 Z28 carbed manual transmission. So on early morning I let my engine warm up(obviously) but when I drove my car for about 40 min and got off the freeway and back on th ethe regular streets I notissed that my car went form idling from 500RPM to about 1500RPM's!??? IDK oif this is normal or what I also put a pikture so that you could see where exactly my RPM gauge is at...
Old Apr 6, 2012 | 06:28 PM
ex-x-fire's Avatar
Re: High Idle...Please help!!
Check for vacuum leaks, tighten up the 4 carb hold down bolts.
When its idling high, look at the carb linkage, maybe it hanging up. Or its on the fast idle cam.
Old Apr 6, 2012 | 08:00 PM
calgutie's Avatar
Car: 1984 Z28
Ok thanks ima check it out...but is there anything else that might cause it???thanks!
and do you know why exactly this happens???
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
