Automatic transmission shifts too early?
Old Apr 12, 2012 | 06:20 PM
RWO3's Avatar
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
I have a 1984 Camaro Sport Coupe V8 with a stock automatic transmission. I feel that while in overdrive, the car shifts into 4th too early. It shifts around 30-35 mph, the engine sounds really low, and it leaves me with very little torque until I reach 45-50 mph.
Is this normal?
When should I be using overdrive anyway? I usually use normal drive until I need to go over 45 mph then shift to OD, then back if I need to accelerate back up from under 45 mph... Is it ok to be shifting back and forth or would it be better just to live with the early shifting?
Thanks.
EDIT: I don't have a tach.
Old Apr 13, 2012 | 09:11 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: Automatic transmission shifts too early?
I would tighten up the tv a notch or 2 and get it shifting into OD at about 45.
Old Apr 13, 2012 | 07:13 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
Check this lnk out make sure your TV cable is set properly ( lot of good iinfo)
http://www.tvmadeez.com/index.php
http://www.tvmadeez.com/article/index.php
Road test the vehicle. Under moderate acceleration your shift points should be close to the following:
1-2…………………15-20 MPH
2-3…………………25-30 MPH
3-4…………………40-45 MPH n.
If the cable is adjusted too loosely your transmission will exhibit soft, stacked shifts (not spread out). DO NOT CONTINUE DRIVING VEHICLE IF THIS HAPPENS! Immediately readjust cable.
Old Apr 15, 2012 | 01:44 PM
RWO3's Avatar
Engine: 355
Axle/Gears: 3.08
1-2…………………15-20 MPH
2-3…………………25-30 MPH
Ok thank you! Ill check it out.
Could a poorly set TV cable also cause the transmission not to downshift when appropriate?
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackphantomZ28
Apr 24, 2016 08:14 AM
3tas4me
Sep 4, 2015 01:45 PM
someone972
Aug 30, 2015 12:52 AM
