timing will advance randomly
Old Apr 15, 2012 | 11:22 AM
warren23's Avatar
okay guys i got a 1989 camaro iroc with 5.7 tpi and auto trans. this car has had no mods done to it it literally is the original motor etc..... now here is my problem. i can set the timing and yes i do it by un hooking spark advance wire at set it at 6 degrees just like my haynes manual says to. it will run great pulls really hard but only for a few miles then randomly the idle will go from 600 to like 1500 even sometimes 2000 rpm. i had the dealership change the tps and iac plus it has a tune up and brand new coolant temp sensor. so it does that randomly but it will also come out of it randomly then will run fine then back again.
i have no vaccum leaks or coolant leaks,oh the dealer here in town has good techs whom i know but seem stumped plus i have no codes.
Old Apr 15, 2012 | 02:45 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: timing will advance randomly
If the base timing is truly changing, then the star wheel on the distributor shaft is loose. Will need a new shaft assembly.
As far as the idle speed increasing a vacuum leak will also cause that.
RBob.
Old Apr 15, 2012 | 02:51 PM
ex-x-fire's Avatar
So its idling high, your title is confusing. They should scan it for iac codes & smooth tps operation. Check the ecm grounds, sometimes all you need to do is loosen them & retighten them, they should be on the back of the heads. It might have a vacuum leak at one of the plenum gaskets, see if they have a smoke machine.
Ghettobird52
Jul 5, 2024 11:18 PM
fonzie85
Aug 13, 2015 11:50 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
