oil pump question
Old Apr 14, 2012 | 12:52 PM
1987_sportcoupe's Avatar
Car: 1987 Sport Coupe
Engine: Carbeurated 5.7
Transmission: NWC T-5
Axle/Gears: Non-posi 2.73
oil pump question
I'm running a stock set up on my 70's 350 that's going in my camaro. My question is where should i weld the pickup to the pump? I mean what location should it be facing?
Old Apr 14, 2012 | 03:10 PM
Re: oil pump question
Such that it's around 3/8" off the bottom of the pan.
Old Apr 14, 2012 | 04:26 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I always braze mine on I don't know if welding might warp the plate. Just something to think about.
Old Apr 14, 2012 | 06:58 PM
Depends on what type of welding.... a wire type, no problem; a torch, .... maybe brazing is better.
I've used both with good results. Brazing has the advantage of being reversible, but is weaker.
Old Apr 14, 2012 | 07:11 PM
Edwardgp's Avatar
Engine: 454-350
Yes sir any way you do it that works just so you do it.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92camaroJoe
Aug 13, 2015 06:07 AM
