car will start then wont
Old Apr 16, 2012 | 06:11 AM
mygmgeneral's Avatar
Car: 1987 camaro
Engine: 2.8 litre fuel injected
Transmission: automatic
one day my car will start, with a boost then the next day it wont start at all,i will get 5,6,7 starts in a row then nothing any solutions?
Old Apr 16, 2012 | 07:27 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: car will start then wont
Need more info. on how the starting system is working. Such as when it dose not start is the engine cranking over.
Old Apr 16, 2012 | 02:09 PM
Car: 1987 camaro
[QUOTE=Edwardgp;5244634]Need more info. on how the starting system is working. Such as when it dose not start is the engine cranking over.[/QUote
yes the engine cranks but there is not ignition, like i said one day it will start AFTER a boost, and keep starting that day, but overnight loses its charge,
Old Apr 16, 2012 | 04:13 PM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
If battery dies overnight that means your alternator/battery bad or your ground cable is not connected/broken
Old Apr 16, 2012 | 04:23 PM
Car: 1987 camaro
thank you
Old Apr 16, 2012 | 06:41 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
Make sure your battery cables are clean and tight, also.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
