ECM or fuel delivery problem???
Old Apr 18, 2012 | 05:15 PM
Goose6's Avatar
Car: 1992 Camaro RS
Transmission: 5 Speed for now
So here's the issue with my 92 RS, 305TBI...I was driving down the road when all of a sudden the car starts to bog down like the fuel flow is being interrupted, or the car is losing spark? The problem goes away, then returns, it's not constant. At the same time the tach is jumping all over the place.
The first time this happened I figured the fuel filter was clogged, so I changed it, problem went away for a couple of days, then returned again. I then started checking plugs, wires, etc. Changed out the ign coil, problem went away, then returned again. Yesterday when the problem started, the tach and speedometer went haywire and the check engine light was flickering like it was doing morse code. I checked the trouble codes when I got home and nothing but 12 showed?! Here's a list of what I changed/did, please help!
Changed; fuel filter, idle air control valve and connector, plugs and wires, ignition coil.
The thing that makes me think it may be an ECM problem is the check eng light going crazy.
Please let me know if anyone has experienced this, or know what the problem might be.
Thanks,
Marcus
Old Apr 18, 2012 | 05:56 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Re: ECM or fuel delivery problem???
What was the tempature out side that day? not your cars temp.
How long were you driving before this problem accured?
I'm thinking you may be having an issue with fuel pressure in your tank.
As maybe not enough as there is supposed to be to help the fuel pump.
Old Apr 18, 2012 | 06:00 PM
Goose6's Avatar
Car: 1992 Camaro RS
It was in the mid-80's. The problem usually gets bad when I drive home, not when I leave in the morning. In the afternoon it's worse.
Old Apr 18, 2012 | 08:10 PM
Car: 1987 Trans Am
Engine: 355 tpi
It sounds to me like you are having a vapor issue.
I would do a few checks Like a pressure on the fuel tank, as there is not to be a pressure drop there. Like when they do it for emmisions testing. You could have a bad gas cap or it could be your purge valve in your vapor recovery systerm. And along those lines you may want to check the charcoal canister. THe purge valve is a simple vacuum test. It should hold a vacuum. if it doesn't then it is faulty. And when it goes bad it is open.
Old Apr 19, 2012 | 10:56 AM
Goose6's Avatar
Car: 1992 Camaro RS
Thanks, I would have never thought of that. I will check it and get back to you.
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Jae992
Aug 27, 2015 09:07 AM
92camaroJoe
Aug 13, 2015 06:07 AM
